As a British engineering company, Hi Spec Motorsport Ltd
manufactures conversions, calipers and rotors at our premises in Dartford, Kent.
With over 25 years of experience making brake components, Hi Spec Motorsport Ltd can manufacture conversations for all vehicles.
Please select options below and add to cart to view cost of brake kit
Hi Spec’s entire range of calipers are made from highest quality billet aluminium.
Hi Spec calipers are made to extreme specifications and tolerances.
Hi Spec road calipers are designed, tested and proven to be used on race cars.
Hi Spec road calipers are available in hard anodised black for function or powdercoat red, yellow, blue, black or silver.
Hi Spec road calipers (except our Ultralight range) come equipped with dust boots to keep dust, dirt and grime away from the piston seals.
15” Front Road Brake kits
2 piece disc brake kit contents example picture
Billet 4 -
Our Billet 4 brake kits are great value for money and the calipers are immensely popular due to this fact. They offer great performance on light vehicles not running too much power and are used on the road.
Please check out our Billet 4 caliper section for more information.
Monster Brake kits
Monster calipers look stunning as well being pretty robust. They are suited for light to middle weight vehicles that are running decent power and used on road and track.
They are more suited to heavy use than the Billet 4, due to a larger pad area.
Please check out our Monster caliper section for more information.
Monster 4 vs Monster 6 Brake kits
One of the main difference between the two calipers is that the Monster 4 is a 4 pot caliper and the Monster 6 is a 6 pot caliper.
Aesthetically the Monster 6 looks better and also functions better as being a 6 pot caliper, it has been engineered to drastically decrease and almost eliminate pad taper wear.
Hi Spec 2 piece disc brake kits contain:
A pair of radial mount calipers.
A pair of mounting brackets and hardware.
A pair of bells and hardware.
A pair of curved 48 vane rotors.
Recommended brake kits as per wheel size below:
Please request wheel clearance diagram to be absolutely sure our brake kit will clear your wheels!
Road or Race |
Minimum recommended wheel size |
Caliper |
1 or 2 piece disc |
Disc/Rotor Size |
Road kit |
15” Wheel |
Billet 4 |
2 Piece Disc |
285 |
Road kit |
15” Wheel |
Monster 4 |
2 Piece Disc |
285 |
Road kit |
15” Wheel |
Monster 6 |
2 Piece Disc |
285 |
